Nautilus041's avatar
Nautilus041
GS 724Tv2 cannot be accesd anymore after password change
Dear Community,   while I did my latest change of the password to the GS724Tv2, I decided to use the full possible 20 character. The change itself seems to be succesfull, as I cannot longer use my...
  • DaneA's avatar
    Feb 20, 2017
    Hi Nautilus041,
    Welcome to the community! :)
    Kindly answer the questions below:
    a. Is the GS724Tv2 switch still working fine even though you cannot login to its web-GUI?
    b. Have you tried to clear the cache/history of the browser you're using then try again to login to the web-GUI of the GS724Tv2?
    c. Have you tried using other browsers like Firefox or Safari to isolate the problem?
    d. Have you tried using other PC or laptop to isolate the problem?
    If ever your answer is "yes" from the questions above and still same problem, I suggest you to perform a factory reset on the GS724Tv2 switch then reconfigure it from scratch.
    DaneA
    NETGEAR Community Team
ProSupport for Business
