jakew8
Jul 08, 2019Follower
GS105Ev2 - IP address after power outage
My router is set to assign my GS105Ev2 switch a specific IP address through DHCP. My setup is at home, so sometimes we have a power outage. When power is restored, all devices restart at the same time. Apparently my switch starts up more quickly than my router.
The result is that when the switch starts up, the router's DHCP server isn't back up yet, so the switch defaults to 192.168.0.239, which I don't want. I then have to cycle the power to the switch (read: crawl under the desk to unplug it and restart it), after which it will see the by now up-and-running DHCP server and use the DHCP-assigned IP address.
My suggestion: a feature where the switch will wait for a number of seconds after powering before looking for a DHCP server. Could be in a future firmware update.
Any other suggestions? Thanks.
Hi jakew8,
Welcome to our community! :)
It would be better if you will just set a static IP to your switch so that once it boots up, it will automatically stay connected. You may use the Prosafe Plus Utility in order to set it to static IP.
JohnCarloV
NETGEAR Community Team
1 Reply
- JohnC_VNETGEAR Employee Retired
Hi jakew8,
JohnCarloV
