gbeddow
Oct 20, 2021Luminary
GS105Ev2 admin page works, but nothing else does
The GS105Ev2 I bought 5 or 6 years ago has been working fine until recently when the (single) video camera attached to it stopped working. The latter is getting PoE, but no communication. The adm...
- Oct 21, 2021
Thanks everyone for the respones. The web page for the GS105Ev2 does indeed work, but I discovered later that a different PoE switch was responsible for the problem. Sorry for the goose chase!
DaneA
Oct 21, 2021NETGEAR Employee Retired
What is the current firmware version of your GS105Ev2? If it is not yet updated, I advise you to update it to the latest version then check if the same problem will occur. The latest GS105Ev2 firmware is v1.6.0.10. You can download it here.
DaneA
NETGEAR Community Team
- schumakuOct 21, 2021Guru - Experienced User
gbeddow I'm a little bit confused - the mentioned GS105Ev2 isn't a PoE switch. Do we face a GS105PE 5-Port Gigabit Ethernet PD-Powered/PoE Pass-thru Plus Switch instead here? That's the only 5-port with PoE...
- gbeddowOct 21, 2021Luminary
