Shawn_Li's avatar
Shawn_Li
Initiate
Jun 16, 2022
GS105Ev2 after foctory defauts no bootloader can upload
My GS105Ev2 when I do factory default and access 192.168.0.239 page, will only ask me to upgrade bootloader, no other page can selected The page prompt message: Bootloader upgrade from file: [ ] B...
  • Shawn_Li's avatar
    Jun 16, 2022
    Let me answer my own questions.... I downloaded the zip file of the old firmware (v1.5.0), found the bootloader file in it and tried to upload it, and finally used v1.4.0.5-VB to successfully update and enter the management page
    I think Netgear needs to provide these necessary files with every firmware release, even if it is not necessarily used
ProSupport for Business
