miltonreg
Feb 24, 2022Aspirant
GS105PE default password isn't working
Hi, I recently purchased a brand new GS105PE switch, but I can't login to the admin page. According to the manual tha came with the device, as well as the one I found on the support page, the def...
Marc_V
Feb 24, 2022NETGEAR Employee Retired
Yes, you are right the default password should be password. Have you tried using a different browser? or clearing the web data?
If you have already tried using a different browser, try doing a factory reset on the switch and then try to access it again.
HTH
