miltonreg
Feb 24, 2022Aspirant
GS105PE default password isn't working
Hi, I recently purchased a brand new GS105PE switch, but I can't login to the admin page. According to the manual tha came with the device, as well as the one I found on the support page, the def...
miltonreg
Feb 25, 2022Aspirant
Yes, I tried different browsers on normal and private/incognito mode, but none of them worked.
I can give it a try reseting the device. Do you know by chance the link to the instructions of how to do it?
