restrepo
May 24, 2021Aspirant
GS108E-300NAS configuration to prioritize VoIP connection
Hello geeks... I recently purchased a GS108E-300NAS for my new home-office network upgrade. I am experiencing some choppy audio on my Polycom Soindpoint IP550 (VoIP phone) which is connected to Por...
DaneA
May 31, 2021NETGEAR Employee Retired
Welcome to the community! :)
Is there a VLAN dedicated for the Polycom Soindpoint IP550? If yes, make sure that port 7 is set as tagged with a PVID of 1.
What is the current firmware version of your GS108Ev3 switch?
How is everything connected? It would be best if you would post a detailed diagram of your existing network so that other community members could post their suggestions and recommendations.
DaneA
NETGEAR Community Team
- restrepoJun 02, 2021Aspirant
Hello DaneA,
Here are the answers...
"Is there a VLAN dedicated for the Polycom Soindpoint IP550? If yes, make sure that port 7 is set as tagged with a PVID of 1."
There is no dedicated VLAN. Should I be using a VLAN? By the way, this is only one (Qty=1) VoIP phone connected to Nextiva.
The only thing I have done is to define QoS Mode as Port based, and Port 7 as High Priority.
"What is the current firmware version of your GS108Ev3 switch?"
Firmware is current... V2.06.14EN
"How is everything connected? It would be best if you would post a detailed diagram of your existing network so that other community members could post their suggestions and recommendations."
I have attached a jpg file with the complete configuration. This is a very simple network.
Thanks in advance for the tips and recommendations.
