crmontoy1's avatar
crmontoy1
Apprentice
Mar 08, 2022
xr500 netgear QoS traffic prioritization
i got a question!! i want to know what happen if i check this box....(apply to WAN)???
what is the funtionality of this? i play PS5
  • The way it's currently configured is fine, assuming you're not having any NAT issues etc.
  • Apply to WAN appends the same priority tags to your game traffic as it leaves the WAN interface. It's hard to know whether it will prioritised by the upstream router/ISP equipment, but there's no harm in doing it.
    • crmontoy1's avatar
      crmontoy1
      Apprentice
      Thks for your answer but what can u suggest me? Check the box or not? Im curious with that box i dont know the funcionality if will be helpful or not?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        We recommend enabling it, if it works you'll see a benefit, if it doesn't it won't cause any negative affects.
