netzafänger
Apr 01, 2019Aspirant
GS108E-300PES - Access statistical information
Hi all,
Is there a way to get statistical data from switch. I want to put it to InfluxDB.
Thanks!
- Apr 01, 2019
Netgear's Smart Managed Plus are almost non-managed switches with very restricted abilities to configure things. Beyond of what is available in the Web UI, not much you can do - e.g. no SNMP, no RMON or the like.
schumaku
Apr 01, 2019Guru - Experienced User
netzafänger
Apr 02, 2019Aspirant
Danke schoen.
At least I have VLAN :)
- schumakuApr 02, 2019Guru - Experienced User
Genre doch, keine Ursache!
There are some hacks around NSDP or attempts on getting the few data out of the Netgear Smart Managed Plus Web UI - some searching the net might help, afraid, not that much these days.
