Sailor1945
Jul 16, 2022Aspirant
GS108E shows 'Located on IP Network' value that is the same as the IP of my desktop PC ???
To avoid unrelated questions, I have removed all other items from my network. Everything has been rebooted from a cold start. My modem/router is configured at 10.0.0.138 and has its DHCP server enab...
- Jul 19, 2022
Sailor1945 wrote:
My concern (question) is that when I run the switch Configuration Utility, it shows the switch details correctly, except for the last column 'Located on IP Network' where it shows 10.0.0.253, which is the address of my PC. By my understanding, that isn't even a (the) network address. What is that column intended to show? And how come my PC's address is there?
This designation of "Located on IP network" is just confusing. Of course it's not a network address - much more the utility does indeed show the IP address of the PC adapter connecting to the IP subnet from where the switch is discovered.
Sailor1945 wrote:
Thanks schumaku, but I'm afraid NSDT 1.2.103 doesn't find my switch at all.
NDST is technically much less challenging than the legacy utility which requires the installation of a low level packet driver for the obsolete Adobe Flash environment allowing access the network using the not very secure NSDP Netgear Switch Discovery (and admin) protocol.
Could be firewall, network location or certain Internet security potentially blocking.
You can always use the switch IP address as seen in the router DHCP table for example to access the switch from a Web browser.
Sailor1945
Jul 19, 2022Aspirant
Thanks schumaku, but I'm afraid NSDT 1.2.103 doesn't find my switch at all. I've attached a snapshot of the ProSafe window in question.
schumaku
Jul 19, 2022Guru - Experienced User
- Sailor1945Jul 19, 2022Aspirant
schumaku wrote:
This designation of "Located on IP network" is just confusing. Of course it's not a network addressI'm glad we agree...
You can always use the switch IP address as seen in the router DHCP table for example to access the switch from a Web browser.My switch is a v2, not a v3, so I wouldn't expect it to respond to any http traffic. (it doesn't)
Anyway, it doesn't appear to affect the switch operation (in my simple use) so I'm happy to call it quits.🙂
Thanks for your interest.
