xsv's avatar
xsv
GS108E turn off EEE?
Hi,
Is it possible to completely turn off the EEE (Energy Efficiency Settings) on the GS108E Switch?\
I have situation where the unmanaged switch is going to sleep and disconnecting from part of the network.
  • Hi xsv,
    Welcome to the community! :)
    As I have research about your concern, there is no option to turn off EEE (Energy Efficiency Settings) on the GS108E switch.  As reference, kindly read page 61 of the Gigabit Web Managed (Plus) Switches user manual here  where it says:  "Power saving options are available only on these Unmanaged Plus Switch models GS105Ev2, GS105PE, GS116Ev2, JGS516PE, JGS524Ev2, and JGS524PE."
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi xsv,
    DaneA
    • DaneA's avatar
      DaneA
      xsv,
      I just want to follow-up on this.  Let us know if you have further questions.
      Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
      DaneA
      • xsv's avatar
        xsv
        Thanks Dane - pitty there is no 8 port model with this option...  Thank you for your quick response.
ProSupport for Business
