nilotots
Jan 31, 2024Aspirant
GS108E V2 vs V3
Hi,
as far as I know the difference between v2 and v3 is the web-interface for configuration.
But how can I tell if a switch is v2 or v3?
I may buy a used one and need to tell the non-tech-savvy seller how to determine the version.
Many thanks.
Hello nilotots ,Welcome to the Netgear Community!
This is correct.
A photo of the physical device, especially the labels of the device (backside, and/or the original color box with the labels attached) could give some insight.
Alternate, run the Warranty Check and input the device serial number.
Similar, I would imagine the Netgear Switch Discovery Tool run on the network with the switch connected, would show the version, too.
-Kurt
