paulowayno's avatar
paulowayno
Follower
Jul 28, 2023
GS108Ev2 Setup
Hello.
I'm new to using this type of equipment, so please forgive the basic questions.
I just purchase a used Netgear GS108Ev2 switch from a discount store. I bought it so I could run a DAW for composing music on my main computer and all the instrument sample libraries on a second computer.
I have tried in vain to set it up. I managed to download the ProSAFE Plus Configuration Utility thinking it would do something, however it says the managerIP and the switch are under a differnt subnet.
Please enlighten me how I can get this setup. I just need the computers to find each other and be able to access files.
Thank you in advance!
1 Reply
  • schumaku's avatar
    schumaku
    One would assume the default is set to DHCP, and the switch will get an IP address from your router LAN DHCP server. Cold reboot while the router and the rest of the network is connected.
    The default LAN IP is 192.168.0.239/24, configure your computer adapter LAN IP to an address in this subnet, something like 192.168.0.123 255.255.255.0 default gw 192.168.0.123
    If the utility does unveil a different IP address, consider a factory reset. Press the reset button for about 7 seconds.
ProSupport for Business
