Hartnett
Mar 14, 2024Guide
WGR614v10 setup?
I'm trying to use a WGR614v10 that has been reset (to its factory defaults). Everything I find about doing this points me to the NIGHTHAWK app. But the Nighthawk app DOESN'T support the WGR614v10. I've tried using http://www.routerlogin.net, but that takes me to a general Netgear page which, among other things, tells me to setup my router with the NIGHTHAWK app. (Been there, Done that. It ended badly.)
Any advice?
Thanks,
Tom
For what it's worth...
I checked some notes I had from more than 10 years ago (so long ago I'd forgotten all about it), when I had an earlier version of the WGR614v10 (it was the -v9) that I setup for my parents, and I had the same problem(s) back then. The "fix" turned out to be accessing the router via "192.168.1.1/start.htm." I did that and the rest was, as they say, history (i.e., it worked fine)
Tom
- HartnettGuide
Hi,
This is a re-do if a post I did a few minutes ago...
I have a WGR614v10 that has been reset (to its factory defaults), and I'm trying to set it up.
I tried http://www.routerlogin.net and that took me to a Netgear page that told me to use the NIGHTHAWK app. But the NIGHTHAWK app DOESN'T support the WGR164v10.
Any pointers?
Thanks,
Tom
usually at the bottom is a link "i don't have a smart phone". Click that.
I'd highly look at upgrading that router. its old, slow, and going to bottleneck pretty much anything you do
- HartnettGuide
Thanks. But..
(1) NIGHTHAWK app says "WGR614v10 - The app does not support your router model." The only real option it give me is to "Open ROUTERLOGIN,NET" (which, in turn, tells me to use NIGHTHAWK... rinse, lather, repeat).
(2) I know it's old/slow, but I'm not using it for my main router. I'm just using it to experiment (screw around) with a handful of "smart" connected devices. (IoT stuff: smart plugs, security camera, etc.)
Tom
