Thunder7
Oct 08, 2015Aspirant
GS108ev3 - Utility stops responding
Just purhcased a GS108Ev3 switch, and I was able to open up the ProSafe Plus Config utility and select the switch to assign an IP address. The switch is working with the attached devices, and I can ping it via the IP assigned to it. My computer I am trying to access the switch with via the utility is in the same subnet. But, I cannot do any other "management" on the switch. When I click the APPLY button once highlighting the switch, I am prompted for the password (which is still the default as I cannot get beyond this to change it), so I enter that, and then the utlity just sits there with its "busy" icon for the mouse cursor. It never comes back, I cannot select any other actions in the utility. I have to kill the utility completely. Any ideas so I can do other settings/fireware updates?
Well, just realized that this version has web management....so nevermind. I am able to mange it via the web interface.
1 Reply
- Thunder7Aspirant
- Apr 12, 2023Retired_Member
