EricBodie
Mar 12, 2022Aspirant
GS108Ev3 camera going offline...
Hi, I have several devices connected to my switch . The problem is when I start up my pc, the connected camera goes offline....when I switch the pc off the camera comes back online a...
- Mar 30, 2022
Hi,
I will cancel my help request because I did put the lan cable from my camera in to a powerswitch and still having the same problem so I quess it has to do with the router or the camera itself.
Thank you for your help and keep up the good work...take care..
Greetings Eric
DaneA
Mar 17, 2022NETGEAR Employee Retired
Are there any settings configured on your GS108Ev3 like VLAN or are you using the GS108Ev3 just like an unmanaged switch?
Are you using a CAT5E ethernet cable on both of your PC and camera?
What is the brand and specific model of your camera?
Is the firmware of your camera updated? If not, you might need to update the firmware of it.
Regards.
DaneA
NETGEAR Community Team
EricBodie
Mar 30, 2022Aspirant
Hi,
Greetings Eric
- Apr 12, 2023Retired_Member
