max_kr
May 14, 2021Tutor
GS108EV3 Webinterface not working on WiFi aft FW-Upgrade
Hi, I made an upgrade to version 2.06.14 have static IPs but can reach my two Netgear switches from my notebook only if it's connect by wire (LAN) via web interface (in the same subnet). If I try to...
DaneA
May 20, 2021NETGEAR Employee Retired
Welcome to the community! :)
Let us try this. Since you have newly updated the firmware, kindly try to perform a factory reset on your GS108Ev3 then reconfigure the settings from scratch in order to start clean using the latest firmware. Then, observe if the same problem will happen.
DaneA
NETGEAR Community Team
- max_krMay 20, 2021Tutor
Hi DaneA,
I did a fatctory reset and tried a clean configuration but problem still persists. Do you have another idea?
Max
- DaneAMay 25, 2021NETGEAR Employee Retired
Are the 2 Ubiquiti AC Pro APs directly connected to the GS108Ev3? If yes, can you try to remove the WPA2 security and try to check if you can access the web-GUI of the GS108Ev3 via an unsecured wireless connection. Make sure to clear the cache on your browser or try to use Incognito Mode on Google Chrome.
DaneA
- max_krMay 25, 2021Tutor
Hi DaneA,
I already created a new wireless network without WPA2, as Ubiquiti support recommened, but with no luck. Wireless from other hosts is working well. Firewall and anti virus on my notebook was completeley disabled. And I also tried icognito modes of Chrome and Firefox and cleard cache and so on. But I guess, telnet via port 80 should work?
The router is connected to a Negear GS116 one GS108V3 and a Zyxel GS1900-10HP (POE) are connected there. The Ubiquiti APs are connected and powered via the Zyxel PoE. The second GS108V3 is connected two the fist GS108V3.
Max
- DaneAJun 02, 2021NETGEAR Employee Retired
I apologize for the late response. :( As far as I have checked, there is no issue logged pertaining to the concern you have described here.
What was the previous firmware version of your GS108Ev3 before you upgraded it to the latest version (v2.06.14)? To further isolate the problem, kindly try to downgrade the firmware of the GS108Ev3 to its previous version then check if the problem will be gone.Regards,
DaneA
- Apr 12, 2023Retired_Member
- May 25, 2022Retired_Member
