max_kr
May 14, 2021Tutor
GS108EV3 Webinterface not working on WiFi aft FW-Upgrade
Hi, I made an upgrade to version 2.06.14 have static IPs but can reach my two Netgear switches from my notebook only if it's connect by wire (LAN) via web interface (in the same subnet). If I try to...
DaneA
May 20, 2021NETGEAR Employee Retired
Welcome to the community! :)
Let us try this. Since you have newly updated the firmware, kindly try to perform a factory reset on your GS108Ev3 then reconfigure the settings from scratch in order to start clean using the latest firmware. Then, observe if the same problem will happen.
DaneA
NETGEAR Community Team
max_kr
May 20, 2021Tutor
Hi DaneA,
I did a fatctory reset and tried a clean configuration but problem still persists. Do you have another idea?
Max
- Apr 12, 2023Retired_Member
- May 25, 2022Retired_Member
