max_kr
May 14, 2021Tutor
GS108EV3 Webinterface not working on WiFi aft FW-Upgrade
Hi, I made an upgrade to version 2.06.14 have static IPs but can reach my two Netgear switches from my notebook only if it's connect by wire (LAN) via web interface (in the same subnet). If I try to...
max_kr
May 25, 2021Tutor
Hi DaneA,
I already created a new wireless network without WPA2, as Ubiquiti support recommened, but with no luck. Wireless from other hosts is working well. Firewall and anti virus on my notebook was completeley disabled. And I also tried icognito modes of Chrome and Firefox and cleard cache and so on. But I guess, telnet via port 80 should work?
The router is connected to a Negear GS116 one GS108V3 and a Zyxel GS1900-10HP (POE) are connected there. The Ubiquiti APs are connected and powered via the Zyxel PoE. The second GS108V3 is connected two the fist GS108V3.
Max
DaneA
Jun 02, 2021NETGEAR Employee Retired
I apologize for the late response. :( As far as I have checked, there is no issue logged pertaining to the concern you have described here.
What was the previous firmware version of your GS108Ev3 before you upgraded it to the latest version (v2.06.14)? To further isolate the problem, kindly try to downgrade the firmware of the GS108Ev3 to its previous version then check if the problem will be gone.
DaneA
NETGEAR Community Team
- schumakuJun 02, 2021Guru - Experienced User
DaneA wrote:I apologize for the late response. :( As far as I have checked, there is no issue logged pertaining to the concern you have described here.
Start your exploration here -> GS108EV3 Webinterface not working on WiFi aft FW-Upgrade .... reads to one of the two issues very similar to me.
- max_krJun 02, 2021Tutor
Thank you DaneA,
I willl try a downgrade to V2.06.10. That is the version I used before.As a workaround I can get access from another computer connected by RDP or if I am connected to LAN.
Because ProSafe Utility is also working all the time, I guess we can close this issue.
Thank you & best regards,
Max
- Apr 12, 2023Retired_Member
- May 25, 2022Retired_Member
