mwhitlock's avatar
mwhitlock
Initiate
Dec 23, 2023
GS108Ev3 won't save Power Saving Mode
The Netgear GS108Ev3 Plus Switch running firmware V2.06.24EN will not save the Power Saving Mode setting on the Switch Information page. There are multiple bugs/deficiencies in the UI that cause this inability to save the setting:
  • Clicking the "Power Saving Mode" radio buttons does not enable the "Apply" button at the top of the page, but you can change some other setting on the page (and then change it back) to force the "Apply" button to be enabled.
  • Clicking the "Power Saving Mode" radio buttons attempts to call a JavaScript function named "enablePwrSavBtns", which is not defined and so results in an error that is logged to the JavaScript console.
  • The "Power Saving Mode" radio buttons are contained in a separate HTML form versus the rest of the settings on the "Switch Information" page, so the "Apply" button actually submits the wrong form and does not submit the selected power saving mode at all.
It is actually possible to apply the selected power saving mode by opening the JavaScript console and executing "document.pwrSaving.submit()" to manually submit the separate HTML form that contains the "Power Saving Mode" radio buttons, but obviously this is hackish, and most users could not be expected to figure this out.
  • Thanks for the tip. While on the System > Management > Switch Information page I pressed Ctrl+Shift+J on my keyboard to open the JavaScript console in an Edge Browser.
    After clicking the Enable radio button under Power Saving Mode I pasted the following into the console:
    window.frames['maincontent'].document.pwrSaving.submit();
    Since this was the first time using the console I was prompted to type "allow pasting"
    I verified the power saving enable option persisted by rebooting the  switch.  Sure enough the Power Save Mode stayed enabled.
  • Oddly, now enablePwrSavBtns() is defined (in function.js), and the buttons do get enabled when I click on one of the "Power Saving Mode" radio buttons. I think the function.js from the previous firmware version was cached in my browser due to the "Cache-Control: max-age=36000" HTTP response header. Maybe the cache-busting "?v1.10" query string was not bumped when function.js was modified for firmware V2.06.24. Anyway, clearing the browser cache (or waiting 10 hours for the cached resource to expire) gets it working as intended.
ProSupport for Business
