tagme
Jun 07, 2019Aspirant
GS108PE 802.1Q VLAN - PVID not applied to untagged packets on trunk port
Hi there! I am using the 802.1q advanced configuration on this switch. I wonder if the PVID tag is applied to untagged packets coming in on a trunk port. There is no indication in the manual tha...
- Jun 07, 2019
tagme wrote:I am using the 802.1q advanced configuration on this switch. I wonder if the PVID tag is applied to untagged packets coming in on a trunk port.
That's what the PVID configuration is for.
tagme wrote:My use case is a wireless access point, that sends its management traffic untagged, while sending different WLAN SSID traffic with a 802.1q tag.
Management VLAN ID: [U]ntagged, same PIVD
WLAN SSID VLAN IT: [T]agged.
schumaku
Jun 07, 2019Guru - Experienced User
- May 25, 2022Retired_Member
