Ivano2105
Nov 21, 2017Aspirant
GS108PE different versions
 I would like to know what are the differences between versions v1, v2 and v3.     Thanks.     Best regards
- Nov 21, 2017I recommend you the GS108PEv3 because it can be managed either using the ProSAFE Plus Configuration Utility or its web-GUI which is convenient. Whereas both the GS108PEv1 and GS108EPEv2 can only be managed using the ProSAFE Plus Configuration Utility. Also, the GS108PEv3 switch has a PoE budget of 53 Watts. Whereas, both the GS108PEv1 and GS108EPEv2 switches which have a PoE budget of 45 Watts. For more information, kindly access their respective data sheets below: Regards, DaneA NETGEAR Community Team
DaneA
Nov 21, 2017NETGEAR Employee Retired
DaneA
