rfcat_vk
Jul 26, 2022Aspirant
GS108Pe v3 interrupted during firmware upgrade and no longer provides access to GUI
Hi folks, I have looked at a number of threads on a similar subject and sort of received an answer. 1/. the device still works as an unmanaged switch 2/. reset to factory defaults does not work 3...
- Jul 27, 2022
With the device being in bootloader mode, the default 192.168.0.239/24 can be in place - so plan a computer in that same subnet.
schumaku
Jul 27, 2022Guru - Experienced User
Hope you have a Windows system at hand. Head to the GS108PEv3 Firmware and Download Pages and install and run the (old, hardcore, ...) ProSAFE Plus Configuration Utility v2.7.8 - this might help to re-install the firmware again.
- rfcat_vkJul 27, 2022Aspirant
Thank you. I will give your suggestion try tomorrow when I have free access to the switch.
Ian
- schumakuJul 27, 2022Guru - Experienced User
Hi folks,
thank you for the suggestions. I had success this morning with accessing the switch, it immediately wanted to continue the firmware upgrade.
Since completing the upgrade it is much moree responsive. A little side not for others in this position, the reset to default did not work while in boot loader mode.
All is now good.
Ian
