rfcat_vk
Jul 26, 2022Aspirant
GS108Pe v3 interrupted during firmware upgrade and no longer provides access to GUI
Hi folks, I have looked at a number of threads on a similar subject and sort of received an answer. 1/. the device still works as an unmanaged switch 2/. reset to factory defaults does not work 3...
- Jul 27, 2022
With the device being in bootloader mode, the default 192.168.0.239/24 can be in place - so plan a computer in that same subnet.
schumaku
Jul 27, 2022Guru - Experienced User
Hope you have a Windows system at hand. Head to the GS108PEv3 Firmware and Download Pages and install and run the (old, hardcore, ...) ProSAFE Plus Configuration Utility v2.7.8 - this might help to re-install the firmware again.
rfcat_vk
Jul 27, 2022Aspirant
Thank you. I will give your suggestion try tomorrow when I have free access to the switch.
Ian
- schumakuJul 27, 2022Guru - Experienced User
- rfcat_vkJul 27, 2022Aspirant
Hi folks,
thank you for the suggestions. I had success this morning with accessing the switch, it immediately wanted to continue the firmware upgrade.
Since completing the upgrade it is much moree responsive. A little side not for others in this position, the reset to default did not work while in boot loader mode.
All is now good.
Ian
- schumakuJul 28, 2022Guru - Experienced User
rfcat_vk wrote:
...I had success this morning with accessing the switch, it immediately wanted to continue the firmware upgrade.
Ian,
For the other readers, what had to be done so the update process continued? Was the switch on it's default IP 192.168.0.239/24 and reachable on this subnet, e.g using a Web browser?
