twindingDK
Feb 09, 2023Follower
GS108PE vs GS110TP
What are the differences between the 2 switches that I have listed above?
- Feb 09, 2023
Who knows? This place is for WiFi routers.
You might get help here:
Switches - NETGEAR Communities
but it could be quicker for you to retrieve the data sheets and manuals for these devices.
Visit the support pages:
Support | NETGEAR
Feed in your model numbers and check the documentation for your hardware.
michaelkenward
Feb 09, 2023Guru - Experienced User
Support | NETGEAR
- May 25, 2022Retired_Member
