Ivano2105's avatar
Ivano2105
GS108PE different versions
I would like to know what are the differences between versions v1, v2 and v3.
Thanks.
Best regards
  • @Ivano2105,
    I recommend you the GS108PEv3 because it can be managed either using the ProSAFE Plus Configuration Utility or its web-GUI which is convenient.  Whereas both the GS108PEv1 and GS108EPEv2 can only be managed using the ProSAFE Plus Configuration Utility.
    Also, the GS108PEv3 switch has a PoE budget of 53 Watts.  Whereas, both the GS108PEv1 and GS108EPEv2 switches which have a PoE budget of 45 Watts.
    For more information, kindly access their respective data sheets below:
    GS108PEv3 Data Sheet
    GS108PEv2 Data Sheet
    GS108PEv1 Data Sheet
    DaneA
    NETGEAR Community Team
