twindingDK
Feb 09, 2023Follower
GS108PE vs GS110TP
What are the differences between the 2 switches that I have listed above?
- Feb 09, 2023
Any specific details you are behind please? Both are gigabit Ethernet switches, different amount of ports, different PoE levels, different power allowance ...
Is the intention to replace the hard to find GS105PE by a GS110TP?
The GS110TPv3 is powered by an external AC adapter, whereas the GS105PE is PoE powered, and has as a very special project device several limitations. both are gigabit Ethernet capable, but the management resp. admin capabilities are basically different..
schumaku
Feb 09, 2023Guru - Experienced User
- May 25, 2022Retired_Member
