mkpotluri
Oct 18, 2020Aspirant
GS108PEv2 Power Failure
Switch was working until I have changed the uplink coming in (from antoher GS108Tv3 managed switch) from Port-8 to Port-1. I have heard a second click besides the RJ45 clicking in from within the swi...
- Oct 20, 2020
Welcome to the community! :)
I verified, the power supply itself is good, showing 48V DC output. However, the switch doesn't show any power on it when plugged-in.
It is strange that the switch suddenly got faulty. I suggest you to open a support ticket with NETGEAR Support here at anytime. Kindly indicate what happened. Be ready to submit a soft copy of the Proof of Purchase or Sales Invoice of the GS108PEv2 for warranty verification. If the hardware warranty is still valid, an online replacement will be processed.
DaneA
NETGEAR Community Team
schumaku
Oct 18, 2020Guru - Experienced User
There is nothing prohibiting such a connection - reads like bad luck.
- DaneAOct 20, 2020NETGEAR Employee Retired
DaneA
- mkpotluriOct 21, 2020Aspirant
Thanks for the responses.
I noticed one thing I have ignored in the last two days - Switch itself is functional, PoE is not working. I was ignoring blinking lights on the ports and focused only on the PoE status lights on the front panel - perhaps fixated too much on getting my desk phone working with PoE.
It looks something *tripped* or *cut* the power to PoE..
It's weird that this happened when I tried to move the upstream from port-8 (non-PoE) to Port-1 (PoE), and the upstream came from GS108T's Port-3 which has no special characteristic and must have been a permissible change.
- mkpotluriOct 26, 2020Aspirant
I did not know this switch carried life time warranty on hardware. I have called the support, and it was replaced.
One thing that still keep me puzzled about this failure - simply switching the uplink cable from one port to another took the power away from PoE (from the switch entirely). However, switch itself was fully functional with ethernet working just as expected. Note that the uplink is fed from another GS108T - so I wasn't expecting there to be a fidelity or compatibility mismatch although there could be.
