robkoon81's avatar
robkoon81
password reset on GS108PEv2
I have one GS108PEv2 switch that does not want to accept the default factory password "password" when trying to manage through the Prosafe Plus Configuration Utility. I know I have never logged into it to change it but I tried to reset it to the factory defaults with the recessed reset button, but that never seems to make the lights blink or reboot, thus does not change anything. Any ideas?
The switch seems to function fine other wise.
  • Retired_Member's avatar
    Retired_Member
    May 17, 2016
    Which version of the ProSafe utility are you using?
    If it's the latest, try downgrading. If it's not the latest, try upgrading.
    Trust me ;)
    Retired_Member
    Trust me ;)
    • JohnRo's avatar
      JohnRo
      NETGEAR Employee Retired
      Hello robkoon81,
      Welcome to the community!
      That is a very good suggestion from Retired_Member. Also, when resetting to defaults try holding the reset button for 30 seconds then turning it off afterwards.
      Let us know what happens.
      Thanks,
    • robkoon81's avatar
      robkoon81
      Changing from version 2.2.6 to 2.2.5 seems to have worked. Thanks
ProSupport for Business
