robkoon81
May 17, 2016Aspirant
password reset on GS108PEv2
I have one GS108PEv2 switch that does not want to accept the default factory password "password" when trying to manage through the Prosafe Plus Configuration Utility. I know I have never logged into ...
- Retired_MemberMay 17, 2016Which version of the ProSafe utility are you using?
If it's the latest, try downgrading. If it's not the latest, try upgrading.
Trust me ;)
Retired_Member
Trust me ;)
Trust me ;)
- JohnRoMay 18, 2016NETGEAR Employee Retired
Hello robkoon81,
Welcome to the community!
That is a very good suggestion from Retired_Member. Also, when resetting to defaults try holding the reset button for 30 seconds then turning it off afterwards.
Let us know what happens.
Thanks,
- robkoon81May 18, 2016Aspirant
Changing from version 2.2.6 to 2.2.5 seems to have worked. Thanks
