KMWNAZ's avatar
KMWNAZ
Tutor
May 01, 2019
Password Reset -
Somehow user and password are not working.  any way to reset it easily?  I've read that logging into Mynetgear and the registered product can elect to "reset password" but that option doesn't appear to be available?  The Orbi is in bridge mode so apparently using the app is also not available?  Any suggestions?
  • KMWNAZ's avatar
    KMWNAZ
    May 06, 2019
    Yes, I've been using the word "bridge" apparently incorrectly for AP mode.  This is how it was setup before I could not get back in.  Still not sure what cause the original password that was set to  not work.  Nonetless I reset it, an dreconfigured it to where it was.  Appreciate everyones willingness to help.
  • If you can't find an alternative option, find a paper clip and Factory Reset is your best friend.  The default username/password is at the bottom of Orbi.  You can change the password afterward.
    • CrimpOn's avatar
      CrimpOn
      Maybe I am missing the point of the question.  The default WiFi SSID and password are on the bottom label. The default administrative user is "admin" and the default password is "password".  So, a person who does not have a computer which can connect to the Orbi with an ethernet cable must (1) factory reset using the paperclip, (2) connect to WiFi using the credentials on the label, then (3) set up the Orbi from scratch.   I have used the option to recover the Orbi password, but it was months and months ago.  As I recall, being able to correctly answer the security questions was a key step in the process.
      • SW_'s avatar
        SW_
        Prodigy
        CrimpOn , thanks for clarifying!
        I'm referring to the default username/password for WiFi setup, which can be found at the bottom of the Orbi's sticker.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi KMWNAZ
    If you are unable to log into the router settings page then there is an option to recover the System's admin password. Here's the reference: https://kb.netgear.com/31016/
    Blanca
    Community Team
    • KMWNAZ's avatar
      KMWNAZ
      Tutor
      Blanca, thanks for the rpely.  I am not able to log into orbilogin.com I believe it is becasue the router is set to bridge mode.
      • FURRYe38's avatar
        You'll need to factory reset the Orbi and walk thru the setup wizard and setup the router from scratch. This time be sure to write down all important information for safe keeping and later use.
  • michaelkenward's avatar
    michaelkenward
    KMWNAZ wrote:
    I've read that logging into Mynetgear and the registered product can elect to "reset password" ....
    Where did you read that?
    You don't say which Orbi device you are using, or which passwords you want to change.
    There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
    >>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
    Search the manual for "password" and it will explain what to do with the various passwords that you can have on these devices.
    • KMWNAZ's avatar
      KMWNAZ
      Tutor
      Thanks for your help.
      Re: Password Reset -
      Where did you read that? I read this here https://kb.netgear.com/000059608/How-do-I-reset-the-admin-password-on-my-NETGEAR-router
      Sorry it's RBR50-100NAS
      >>>> Orbi RBK50 | WiFi System | NETGEAR Support<<<<
      This doesn't appear to workfor me as the Orbiis set to bridge mode.
