mkpotluri's avatar
mkpotluri
GS108PEv2 Power Failure
Switch was working until I have changed the uplink coming in (from antoher GS108Tv3 managed switch) from Port-8 to Port-1. I have heard a second click besides the RJ45 clicking in from within the switch and the power has shutdown. I verified, the power supply itself is good, showing 48V DC output. However, the switch doesn't show any power on it when plugged-in.
Plugging in uplink to Port-1 didn't seem wrong - it came from port-5 of another GS108, has no PoE on it. I am unfamiliar if Prosafe GS108PEv2 forbid such connection - any insight into why this would have happened, and if there is any way I can recover this switch is highly appreciated...
  • DaneA's avatar
    DaneA
    Oct 20, 2020
    mkpotluri,
    Welcome to the community! :)
    It is strange that the switch suddenly got faulty.  I suggest you to open a support ticket with NETGEAR Support here at anytime.  Kindly indicate what happened.   Be ready to submit a soft copy of the Proof of Purchase or Sales Invoice of the GS108PEv2 for warranty verification.  If the hardware warranty is still valid, an online replacement will be processed.
    DaneA
    NETGEAR Community Team
  • schumaku's avatar
    schumaku
    There is nothing prohibiting such a connection - reads like bad luck.
    • DaneA's avatar
      DaneA
      NETGEAR Employee Retired
      mkpotluri,
      DaneA
      • mkpotluri's avatar
        mkpotluri
        Thanks for the responses.
        I noticed one thing I have ignored in the last two days - Switch itself is functional, PoE is not working. I was ignoring blinking lights on the ports and focused only on the PoE status lights on the front panel - perhaps fixated too much on getting my desk phone working with PoE.
        It looks something *tripped* or *cut* the power to PoE..
        It's weird that this happened when I tried to move the upstream from port-8 (non-PoE) to Port-1 (PoE), and the upstream came from GS108T's Port-3 which has no special characteristic and must have been a permissible change.
ProSupport for Business
