robkoon81's avatar
robkoon81
password reset on GS108PEv2
I have one GS108PEv2 switch that does not want to accept the default factory password "password" when trying to manage through the Prosafe Plus Configuration Utility. I know I have never logged into ...
  • Retired_Member's avatar
    Retired_Member
    May 17, 2016
    Which version of the ProSafe utility are you using?
    If it's the latest, try downgrading. If it's not the latest, try upgrading.
    Trust me ;)
ProSupport for Business
