mcsweeney
Nov 21, 2019Aspirant
GS108PEv3 as PD device ?
Hello, I purchased this switch some time ago and it came with an AC adapter. I am now wondering if the device in itself can be powered via POE as a PD device, as I am short on electrical outlets....
- Nov 21, 2019
The Smart Managed Plus GS108PEv3 needs a power supply to operate, it can't be powered as a PD, but it has four PoE ports with a PoE power budget of max 53 W.
FMI: https://www.netgear.com/business/products/switches/web-managed/GS108PE.aspx#tab-techspecsThe confusion is probably coming from the Smart Managed Pro GS108Tv2 switch model. Here the power supply is optional, and the switch can be powered as PD from a PoE switch. There are no PoE ports beyond of the PD port. FMI: https://www.netgear.com/business/products/switches/smart/GS108Tv2.aspx#tab-techspecs
schumaku
Nov 21, 2019Guru - Experienced User
