Fry-kun's avatar
Fry-kun
Can't update GS108PEv3 firmware
I just got a GS108PEv3 and trying to update it to latest firmware, 2.06.10 (it's currently on 2.06.08)
I tried 2 browsers (Firefox, Chrome) and the file upload appears to happen, but the switch doesn't seeem to react at all to that. After several minutes, I open a new tab and open the switch page -- it's in loader mode and responds to reboot command.
Is there a way to use TFTP to upgrade it?
I don't have access to a Windows machine, so the ProSAFE software is out of the question
  • I managed to revive the switch after finding an ancient desktop with Windows XP, installing the proSafe software on it.
    The software found the switch stuck in "flashing" mode and allowed me to finish the flashing.
    There should be a huge disclaimer that says "DO NOT USE FIRMWARE UPGRADE FROM ANY MODERN BROWSER"
    They don't allow setting file upload timeout nowadays...
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Fry-kun,
    Welcome to the community! :)
    Kindly try to perform a factory reset on your GS108PEv3 then try to update again the firmware to the latest version.
    DaneA
    NETGEAR Community Team
    • Fry-kun's avatar
      Fry-kun
      I tried the factory reset and a crazy reset from https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS108Ev3-wont-complete-factory-reset/td-p/1581309
      I'm able to access the switch via the web interface but the upgrade process still gets stuck with progress bar at 100, for many minutes (waited >10min). After that, I open a new tab and go to switch url -- it's still in loader mode -- and I select reboot. It reboots back to normal state with old firmware.
      I read somewhere here that if I hold the factory defaults button for a while, it enters recovery mode -- will TFTP work from there?
      If necessary, I can also open up the unit and use JTAG interface..
    • Fry-kun's avatar
      Fry-kun
      I tried to reset with 2sec and 30/5/5, the effect is still the same:
      * I set the switch to loader mode and upload the update.
      * The progress bar stays at 100% for a long time (10-15min) and I'm able to open the switch UI in a new tab. It's still in loader mode, so the options are to upload another file or reboot.
      * After reboot, it looks fine but still has the old version, V2.06.08EN
      What are the next steps? Is there a recovery mode for TFTP? Worst case, I could use JTAG inside the unit, just need instructions..
      • DaneA's avatar
        DaneA
        Fry-kun,
        Thanks for the feedback.  To further isolate the problem, let us try a different PC/laptop and kindly download again the latest firmware v2.06.10 here.  If I'm not mistaken the file size of the zip file should be about 255KB.  Then, perform the steps I indicated on the forum thread here.
        DaneA
ProSupport for Business
