Fry-kun
Mar 28, 2020Aspirant
Can't update GS108PEv3 firmware
I just got a GS108PEv3 and trying to update it to latest firmware, 2.06.10 (it's currently on 2.06.08) I tried 2 browsers (Firefox, Chrome) and the file upload appears to happen, but the switch does...
- Apr 11, 2020
I managed to revive the switch after finding an ancient desktop with Windows XP, installing the proSafe software on it.
The software found the switch stuck in "flashing" mode and allowed me to finish the flashing.
There should be a huge disclaimer that says "DO NOT USE FIRMWARE UPGRADE FROM ANY MODERN BROWSER"
They don't allow setting file upload timeout nowadays...
Fry-kun
Mar 30, 2020Aspirant
I tried to reset with 2sec and 30/5/5, the effect is still the same:
* I set the switch to loader mode and upload the update.
* The progress bar stays at 100% for a long time (10-15min) and I'm able to open the switch UI in a new tab. It's still in loader mode, so the options are to upload another file or reboot.
* After reboot, it looks fine but still has the old version, V2.06.08EN
What are the next steps? Is there a recovery mode for TFTP? Worst case, I could use JTAG inside the unit, just need instructions..
DaneA
Mar 31, 2020NETGEAR Employee Retired
Thanks for the feedback. To further isolate the problem, let us try a different PC/laptop and kindly download again the latest firmware v2.06.10 here. If I'm not mistaken the file size of the zip file should be about 255KB. Then, perform the steps I indicated on the forum thread here.
DaneA
NETGEAR Community Team
- Fry-kunMar 31, 2020Aspirant
If you have the settings for JTAG interface (voltage/baud/parity/etc.), please tell me if I can upload the firmware that way.
- Fry-kunApr 01, 2020Aspirant
My switch is now broken because of your advice, thanks a lot.
Of course this message will get removed, so I've got that going for me...
- DaneAApr 02, 2020NETGEAR Employee Retired
I apologize that the switch got broken while exhausting the troubleshooting steps. I suggest you to open a support ticket with NETGEAR Support at anytime here to process an online replacement. Be sure to upload a soft copy of the Proof of Purchase or Sales Invoice of your GS108PEv3 for warranty verification. If the hardware warranty is valid, an online replacement will follow.
To know more about the NETGEAR Warranty Return Policy, kindly access the article below:
DaneA
- Fry-kunApr 11, 2020Aspirant
