Tom10036's avatar
Oct 01, 2020
Firmware update c7000v2
My internet is not working. Spectrum told me that I need to update my WiFi router. I installed nighthawk app from iPhone and I’m stuck at the step where it shows firmware out-of-date. From my laptop connected to the router, I went to routerlogin.net. I followed the online instructions on firmware update using netgear genie. Under Advanced-Administration, I don’t see “firmware update” or “router update” option. How do I update firmware? I have NightHawk AC1900 WiFi cable modem router and I use netgear genie firmware version V1.02.09 for model C7000v2. Thanks.
  • So its not getting any signal.
    go to where the coax enters the home and directly connect tthe coax to the modem. This ensures nothing in the home is causing an issue.
  • plemans's avatar
    Modem/router combo devices aren't user updatable. The update has to be pushed by the isp.
    https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
    What issue are you having with the internet? from the sound of it, you're able to connect to the C7000 but it doesn't have access to the spectrum? Can' spectrum ping/see it?
    Do you have a screen snip of the cable connections page and the logs?  get a screen snip of those and post them back here. It lets us check the connection back to the isp.
    Also, if you have any splitters, amplifiers, or attenuators in the coax line, I'd recommend removing them.
      • plemans's avatar
    • Tom10036's avatar
      Tom10036
      Guide
      I was on the phone with spectrum for hours yesterday. Spectrum tried to fix it from their end but couldn’t do it.
