Tom10036
Oct 01, 2020Guide
Firmware update c7000v2
My internet is not working. Spectrum told me that I need to update my WiFi router. I installed nighthawk app from iPhone and I’m stuck at the step where it shows firmware out-of-date. From my laptop c...
- Oct 01, 2020
So its not getting any signal.
go to where the coax enters the home and directly connect tthe coax to the modem. This ensures nothing in the home is causing an issue.
Oct 01, 2020Guru - Experienced User
Modem/router combo devices aren't user updatable. The update has to be pushed by the isp.
What issue are you having with the internet? from the sound of it, you're able to connect to the C7000 but it doesn't have access to the spectrum? Can' spectrum ping/see it?
Do you have a screen snip of the cable connections page and the logs? get a screen snip of those and post them back here. It lets us check the connection back to the isp.
Also, if you have any splitters, amplifiers, or attenuators in the coax line, I'd recommend removing them.
Tom10036
Oct 01, 2020Guide
- plemansOct 01, 2020Guru - Experienced User
- Tom10036Oct 01, 2020GuideIt didn’t make a difference. Hopefully this is a cable issue that Spectrum technician can fix it tomorrow.
- Tom10036Oct 02, 2020GuideCable technician was able to fix it. As you indicated, it wasn’t a problem with netgear. Thanks a bunch!
- plemansOct 03, 2020Guru - Experienced User
glad to hear you got it working!
- Unlucky11Dec 25, 2020InitiateI want to update my netgear modem router
