inittab
Nov 04, 2022Aspirant
GS108PEv3 issues with management network and tagging vlans.
I am currently having issues with a newly purchased GS108PEv3 and accessing the management interface while having multiple tagged vlans.. General Information: VLAN1 (untagged) 10.0.10.0/24, unta...
Retired_Member
Nov 05, 2022
I assume that this 10.0.102.0/24 subnet in so many VLANs is just a typo and you have distinctive subnets in each VLAN. If not, I’m out of this.
Your configuration looks almost fine to me. However, it was difficult for me to understand it because you said “tagged vlans.” Why? Well, you do not tag/untag VLANs. It is quite opposite. You mark certain ports as tagged or untagged when you add them to a VLAN. Basically, you add a port to a VLAN and indicate whether it expects tagged or untagged frames from a device connected to it.
You have Ports 7 and 8 as uplink/down links and their definitions look fine to me, but only if their PVIDs are set to 1. Most of VLAN issues I have seen and I have had myself were caused by wrong PVID! You also need to make sure that the ports on the other side of the links are defined exactly the same way.
Then, you have ports where your end-point devices are connected to. Unless you use some other ways of VLAN assignments, these ports should be members of just one and only one(!) VLAN and their PVID should be set to the VID of the corresponding VLANs. Therefore, you should remove these ports from VLAN 1 to avoid any issue and confusion. What you have observed is something I would’ve expected since you made Port 3 an untagged member of both VLAN 1 and 108.
If I understand your configuration correct, the routing among VLANs is done by the router. So providing all VLAN definitions are correct, if there are still any issues with it, I would look for a cause of it on the router’s side.
inittab
Nov 07, 2022Aspirant
Yep, sorry doesn't look like I can edit now and was doing a lot of copy and pasting in original post, all networks are independent and not on the same ip address scheme.
ex: VLAN101 = 10.0.101.0/24 VLAN102 = 10.0.102.0/24 and so forth.
ports 7 and 8 do have pvid's of 1 with vlan 1 untagged and other vlans tagged
vlan 1 is removed from any ports that have a specific vlan assignment, so ports 1 and 2 do not have vlan 1 marked as untagged or tagged.
switches on other side are configured the same way with an untagged vlan 1 and tagged 101-108,999
ex:
interface 48
name "garage switch to netgear"
tagged vlan 100-108,999
untagged vlan 1
exit
as for the port 3 thing I might not of been clear, I changed port 3 from vlan 1 to vlan 108 (removed it from untagged vlan 1, and changed it's pvid to 108)
- Retired_MemberNov 07, 2022
Also, when experiencing some “erratic” network behavior, I would suspect a broadcast storm due to a network loop or multicasting without control of it. While investigating the issue, I would reduce the number of connections to bare minimum and expand the network gradually observing the impact.
- inittabNov 07, 2022Aspirant
No broadcast issues or multicast issues here, the only issue i'm experiencing is accessing the management interface on this specific switch. the rest of the network (2 hp 48 port switches, 1 udm pro, multiple ip camera's, nas devices, servers, etc) work perfectly fine. It really just seems like this switch has issues when tagging multiple vlans on a port
