mcsweeney
Jul 07, 2019Aspirant
GS108PEv3 PoE Mode A capability ?
Hi, we are contemplating buying some GS108PEv3 switches, or the bigger-port equivalents for our building. We have a number of IP security cameras which are PoE powered. However, many of these are usi...
- Jul 11, 2019
I just got a feedback from the higher tier of NETGEAR Support. The NETGEAR 802.3af/at PoE switches supports ALT-A mode (Ethernet 1,2,3,6 pair) and will deliver power to PD’s (power devices), that should cover 10/100Mbps devices like the the IP camera you have mentioned. If only using 2 pair cable, the you must make sure that the PD supports ALT-A and must use CAT5 for 10/100M, or CAT5E for 1000M (4pair).
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
mcsweeney
Jul 09, 2019Aspirant
Hi, this would be representative of devices we intend to power :
https://hviewsmart.com/collections/wifi-poe-cameras-nvrs/products/h-view-poe-ip-camera-4mp-h-265-cctv-camera-poe-cameras-outdoor-2-8-8mm-motorized-lens-auto-focus-onvif-nas-ip-cameras
DaneA
Jul 11, 2019NETGEAR Employee Retired
DaneA
