NebRedstone
Sep 09, 2020Aspirant
GS108T - Can't login after enabling 802.1x
I’ve logged into the switch at 192.168.0.239 with the default password "password", and I am able to see the switch on the NETGEAR Switch Discovery Tool. Next, I've configured 802.1x on the switch ...
- Sep 09, 2020
Reads like the login is going to the RADIUS server instead of the local authentication. Setup an extra "admin" user with a password of your choice on your RADIUS server to be able to login into the WebUI.
schumaku
Sep 09, 2020Guru - Experienced User
- NebRedstoneSep 11, 2020Aspirant
Close enough! In the end I just had to add "Local" as number 2 on the Authentication List.
- schumakuSep 11, 2020Guru - Experienced User
NebRedstone wrote:In the end I just had to add "Local" as number 2 on the Authentication List.
Yep, completely forgot about this option!
