MyNetworkIsBrok
May 22, 2025Tutor
GS108T not responding and all LED are turned on
Hello. I have a Netgear GS108T that worked great for many years. But starting today, it's no more the case. On the network side, no more packet goes through it. And I cannot access its web i...
- May 22, 2025
Ok, I have 2 switch Netgear GS108T. After connected the not responding switch to the power supply of the other switch, it start correctly.
So, it's the power supply of the switch that cause the problem. Confirmed with a voltmeter: The suspect power supply only deliver 7 volts instead of 12.
Do you know if it's easy to buy only a compatible power supply ?
MyNetworkIsBrok
May 22, 2025Tutor
And, sometimes, the power LED blink. But the number of blink seems to be random and I see no repetitive paterne in it.
