Retired_Member
Dec 13, 2017GS108T Switch Uptime wraps to negative uptime
Topic sas it all really: System Information Switch Status Product Name GS108T System Name System Location Idle Timeout (3 to 3...
- Dec 14, 2017
Hi noibla,
Thanks for your suggestion. We would check it.
Best Regards
Carl
Retired_Member
Dec 14, 2017Hi Carl,
Thanks for th ereply. I removed the IP addresses deliberately as well as the MAC address. The unit has been on for quite a while and probably looped the counter for the uptime. It is likely that the system uptime is stored as a signed integer, however, due to the lenghtly uptime now overflows to the negative.
Best to update the system firmware to have this as an unsigned integer.
Carl_z
Dec 14, 2017NETGEAR Expert
Hi noibla,
Best Regards
Carl
