tonynsx's avatar
tonynsx
Luminary
Jul 27, 2022
GS108T to Aruba 2390F 24 port
I have a Netgear GS108T switch that for some reason only works on an Aruba 2390F 48 port switch.  If I connect the GS108T to an Aruba 2390F 24 port switch, it won't work for some reason. I have both...
  • schumaku's avatar
    Jul 27, 2022
    As we face the same simple GS108T the idea is near that both Aruba switches are not configured the same, or behave different for whatever reason. Probably asking on the wrong community here?
ProSupport for Business
