tonynsx
Jul 27, 2022Luminary
GS108T to Aruba 2390F 24 port
I have a Netgear GS108T switch that for some reason only works on an Aruba 2390F 48 port switch. If I connect the GS108T to an Aruba 2390F 24 port switch, it won't work for some reason. I have both...
- Jul 27, 2022As we face the same simple GS108T the idea is near that both Aruba switches are not configured the same, or behave different for whatever reason. Probably asking on the wrong community here?
schumaku
Jul 27, 2022Guru - Experienced User
tonynsx
Yeah, probably something different on the 24 port Aruba. I didn't setup the switches, so I'm not sure.
Need to look at configs of both.
