jmstanley
Nov 27, 2025Aspirant
gs108v2 gs308ep DoS
I have both of those switches... The port turns off and has to be enabled to back on. The gs108v2 is connected to the gs308ep (poe is turned of on port 1 which connects to the gs108v2 port 1). Th...
Nov 28, 2025Guru - Experienced User
jmstanley wrote:gs 108v2
This particular model is an unmanaged switch - so no logs.
Are you sure you have the exact model info?
Or did you mean to say the GS308ep log?
- jmstanleyNov 28, 2025Aspirant
Correct it's a smart switch not a fully managed switch... The model info I gave is correct also.
Thanks for the reply.
- StephenBNov 28, 2025Guru - Experienced User
Are you sure you didn't mean the GS108eV2 or the GS108Tv2?
The GS108T has a control to disable DOS attacks, the GS108e doesn't (at least nothing in the manual)
- jmstanleyDec 02, 2025Aspirant
It still happens when disable.
