jmstanley
Nov 27, 2025Aspirant
gs108v2 gs308ep DoS
I have both of those switches... The port turns off and has to be enabled to back on. The gs108v2 is connected to the gs308ep (poe is turned of on port 1 which connects to the gs108v2 port 1). Th...
jmstanley
Nov 28, 2025Aspirant
Correct it's a smart switch not a fully managed switch... The model info I gave is correct also.
Thanks for the reply.
Nov 28, 2025Guru - Experienced User
jmstanley wrote:The model info I gave is correct
Are you sure you didn't mean the GS108eV2 or the GS108Tv2?
The GS108T has a control to disable DOS attacks, the GS108e doesn't (at least nothing in the manual)
- jmstanleyDec 02, 2025Aspirant
It still happens when disable.
- StephenBDec 03, 2025Guru - Experienced User
I'm unclear on the topology.
It sounds like Router->gs108->gs308->Cisco AP
Is that right? What other stuff is connected?
Is everything on 192.168.2.x?
- jmstanleyDec 06, 2025Aspirant
Everything is on the same network. Yes, that's the network topology. The network cable is a straight through cable from switch to switch.
Wireless printer has been disconnected and it still happens. It seems from searching, their are other cases of this happening on this forum and no real answer.
