ThiloKoettgen
May 30, 2022Tutor
GS110 TP V3 port restart over SNMP
Hello all, is there a way to switch a network port of the GS110Tp off and on again via snmp or to restart it? By way of background, one of the SFP modules occasionally hangs and we would like to re...
ThiloKoettgen
May 31, 2022Tutor
Hello Schumaku,
I'm sorry to get back to you so late, but I forgot to activate the email notification for replies. Thank you for your efforts.
In the meantime, we have also found a solution.
The OID 1.3.6.1.2.1.2.1.7.(X) (X)=number of the port switch the state of the port up(1) down(2) . The SFP module is also reset when it is switched off, at least that is how it appears 🙂
However, we noticed that the saved configuration is reloaded after a reboot. This means that if I deactivate the port via SNMP and restart the device, the port is activated again.
ThiloKoettgen
Nov 23, 2022Tutor
Small correction the correct OID is 1.3.6.1.2.1.2.2.1.7.(X)
