colclark
Jan 26, 2021Aspirant
GS110EMX - using ports 9 or 10 to link switches in a ring
Hello, I'm wondering about how to use the GS110EMX 9/10 port to link 3 switches to each other to facilitate access to my internet from throughout a building. I'd like to attach wifi access ...
schumaku
Jan 26, 2021Guru - Experienced User
Yes, of course you can.
The "how" depends widely on the ability on how to cable your property making up the network structure, for a daisy chain of these three switches or to set-up a central location with a bigger patch panel where the majority of rooms or areas can be covered with one or better two network cable (one for PoE access point, one for a local switch). And then the bandwidth requirements or expectation for the in-house traffic, as port 9 and 10 on the GS110EMX are MultiGig ports able so drive Gigabit, 2.5Gb/s, 5 Gb/s and 10 Gb/s links.
- colclarkJan 26, 2021Aspirant
Yes, thank you, what I'm looking for specifically is the configuration for ports 9 and 10 given 3 switches hooked together in a ring if I use ports 9 and 10 to connect them.
- schumakuJan 26, 2021Guru - Experienced User
Unless you run VLANs it's plain plug and play - except of this:
The GS110EMX is a lightly configureable switch core, there is no STP, RSTP, or MST - it can't participate in a network with redundant ring layout.
So either some dasy chain...
#9 <-> switch 91 <-> switch 92 <-> switch 93
#10<-> switch 101 <-> switch 102 <-> switch 103
...or hub and spoke...
<-> switch 93
<-> switch 103
sorry, missed the subject "ring"
#9 <-> switch 91 <-> switch 92 <-> switch 93 <-> #10 can't be done (as mentioned above - all switches would require STP [obsolete], RSTP, or MST for a multi VLAN ring design)
Thank you.
