cwoodfield
Nov 29, 2025Aspirant
GS110EMX not tagging frames
I've had this switch for quite a while but haven't had a need to configure VLANs until now. I've started by moving all the ports to Vlan 2, and configuring ports 7 and 8 - part of an LACP bundle - as...
cwoodfield
Dec 01, 2025Aspirant
As an FYI - I am working on the possibility (albeit unlikely) that my upstream router (a Mikrotik RB5009) is stripping the incoming vlan tags off of the packets before handing them to the pcap process. To test that, I attempted to set up a mirror port on the switch, but it appears that I can't use a member of a LAG group as a mirror source:
